2 qiuck questions :) help
* B A N N E D *
i just got the engine started today and i need to know first
1st For the idle screw is Right for ower idle or left for lower idle?
2nd is it ok if i turn on the car with no oil in the tranny?
Re: 2 qiuck questions :) help (ReactioN)
u can turn it on for a bit to look at stuff but dont try to put it in any gear, also right is to raise it i think but just play around good luck
* B A N N E D *
Re: 2 qiuck questions :) help (4doorek96)
pk so left its to lower it?
and because when i turned it on it was raising rpm like i was reving it
yeah im pretty sure left lowers it, as long as it isnt in gear the tranny shouldnt move at all so it should be ok you might wanna cheack pcv valve or some other vac line
* B A N N E D *
I think its because the TB has a place for the FITV and So dose the IM and if i put em both on it wont fit so i left the one from the TB off
if you are never ever going to use them try some type of silicon or something but use your fingers first to make sure its the problem like put your fingers over the holes
* B A N N E D *
i cant use my fingers cause when i turn it on its already raised to about 2 k and it keeps going
project_one42
02-02-2005 06:30 PM
