Loss of Horsepower with A/C?
how much horsepower does hooking up an a/c system take away from a '99 GSR ??
is there any type of a/c compressor available that can minimize the loss of horsepower with respect to the performance of the car?
Re: Loss of Horsepower with A/C? (KILLASmoke)
well i dont know about a B-series but my d-series is real slow with the a/c on, but it only uses a noticeable amount of power when its on anyway. Get some underdrive pulleys if your really worried about power loss. IMO put the A/C on you'll be glad you did when its hot.
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">The car would lagg a little bit while AC is on, but after you turn the AC off.. It will be fine..
And i do not think there is a different compressor.</TD></TR></TABLE>
correct sir
If you think your gsr lags when the a/c is on, you should try driving my Y8 with a/c on. When i'm driving with the a/c on, you can feel the car lose power after 2,000rpm. Especially becuz my car is black, it soaks up all the heat.
correct sir
Re: Loss of Horsepower with A/C? (jimmy o.)
All accessories sap some power. Thats why the new horsepower standards yield less hp from the same engines. Example: With the power-steering pump and A/C compressor attached the 210hp RSX-S makes 201hp.
DOn't buy aftermarket pullies, most of them are not balanced, they don't help with power loss and they will vibrate your crankshaft to death. Just turn off AC when you want the performance, its pretty easy.
Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">DOn't buy aftermarket pullies, most of them are not balanced, they don't help with power loss and they will vibrate your crankshaft to death. Just turn off AC when you want the performance, its pretty easy.</TD></TR></TABLE>
x3
x3
Banned
Re: (1CaMw0nDeR)
of course there would be a slight loss in power, its running off your belts, the mere inertia properties of it all would suggest this. suffice it to say, its nearly common sense bro
but there are no special compressors for what you ask, and the easiest thing to do would be PS/AC delete. but is it worth it for you, when its mere 2-3 whp (if that)?
Re: (br0nx finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by br0nx finest »</TD></TR><TR><TD CLASS="quote">of course there would be a slight loss in power, its running off your belts, the mere inertia properties of it all would suggest this. suffice it to say, its nearly common sense bro
but there are no special compressors for what you ask, and the easiest thing to do would be PS/AC delete. but is it worth it for you, when its mere 2-3 whp (if that)?</TD></TR></TABLE>
I LOVED how my car responded without PS/AC. It def. feels like more than 2-3 hp. Throttle response was improved.
Though there was that chronic Swamp-***...
Global Moderator
Re: (Ice78transam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam »</TD></TR><TR><TD CLASS="quote">
Though there was that chronic Swamp-***... </TD></TR></TABLE>
quote'd so you can't edit..
hahahhahaha...
hahahhahaha...
Re: (Ice78transam)
ive heard the ac belt doesnt run unless its turned on so no strain on the pulley
gaining 2-3 hp from no power steering?
think that makes it more of a preference
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KILLASmoke »</TD></TR><TR><TD CLASS="quote">how much horsepower does hooking up an a/c system take away from a '99 GSR??</TD></TR></TABLE>
There are LOTS of factors at play here, so let's put the 'thinking cap' on...
The compressor... the clutch... the condenser fan... the evaporator fan - these all require electric power, sooo... yes, the alternator drag, yada, yada, yada... plus the added vehicle weight!
The figures I've seen - generically speaking - and ALL things considered - are 5-30 horsepower, depending on who you believe.
I'd *GUESS* - based on my 'seat-of-pants' dyno & gas mileage reduction - 10-15 horsepower on the typical Honda...
Heh!
Give or take 50%, of course...
Heh!
If I was that concerned about the power loss, then I would just take the belts off. That way later on when you want the AC and PS back, all you have to do is put the belts back on. That will also help with resale value since most likely the new owner would want properly functioning A/C and P/S (I know I would).
Banned
Re: (TheJGB3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheJGB3 »</TD></TR><TR><TD CLASS="quote">If I was that concerned about the power loss, then I would just take the belts off. That way later on when you want the AC and PS back, all you have to do is put the belts back on. That will also help with resale value since most likely the new owner would want properly functioning A/C and P/S (I know I would).</TD></TR></TABLE>
agreed
agreed
jlamaster
10-01-2004 07:12 PM
dacaveman
04-14-2003 11:08 PM
