HELP ME...pic and question inside...
Re: HELP ME...pic and question inside... (wilaivue)
Looks like someone had an unwanted visitor........
You'll need a phillips screw driver and most likely an 8mm socket with ratchet. Remove the knee guard on the drivers side. Pop down the glove box. Now on either side of the plastic trim under the radio you'll see two screws (one on top, and one on the bottom for the left and right sides of the trim) take them out to remove the plastic trim under the radio (where the lighter socket is, there may also be two more screws on each side of the lighter socket). The radio will have to come out as well, it's mounted with four 8mm bolts. These are mounted to the radio's two frame arms and can be seen right under the radio (where it sits in the car). The bolts are shinny silver. With them out, pull the bezel toward you and with a little firce it'll pop off. Now you'll have to unplug the heater controls and four way connector. The bezel should be off and out of the way now (with the radio attached to it).
Hope this helps. Cheers.
Modified by SamSpade at 12:22 PM 6/2/2008
wut year and model is that?
and just curious...did you break that trying to get it out or did someone try to jack yur stuff? lol
Re: HELP ME...pic and question inside... (civics4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civics4lyfe »</TD></TR><TR><TD CLASS="quote">wut year and model is that?
and just curious...did you break that trying to get it out or did someone try to jack yur stuff? lol</TD></TR></TABLE>
99-00 civic. Not an si.
matt94z
Audio / Security / Video
02-15-2009 10:58 AM
