How can you identify which fuel injector is which?
PHANTOM MENACE
I've been searching with no luck. My specific question is "Is there a way to identify what specific fuel injector you have?" So far in my search, I've found that of all the 92-95 models, they all use the same injectors EXCEPT for the 8 valve CX hatchback (which happens to be the car I have). Any help anyone?
Re: How can you identify which fuel injector is which? (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">I've been searching with no luck. My specific question is "Is there a way to identify what specific fuel injector you have?" So far in my search, I've found that of all the 92-95 models, they all use the same injectors EXCEPT for the 8 valve CX hatchback (which happens to be the car I have). Any help anyone? </TD></TR></TABLE>
other than flow test ( for cc flow)
you can take a multimeter and find out the resitence to see if it is a peak/hold or sat injector.
also the manufactere and color are some giveaway's
Ie RDX injectors being bright blue (how i tell where they are in the garage )
other wise check the plugs obd0/1/2a/b
PHANTOM MENACE
Re: How can you identify which fuel injector is which? (i drive a honda)
Hmmm they are all the same OBD version (OBD1) but I could've sworn that there was a slight difference in color. It's daytime now so I'll go take a look at them.
wiZCo
02-13-2007 12:52 PM
TheThiefTheKnife'NTheGun
06-26-2006 11:45 PM
