White Smoke from B20 Swap? Rings? Coolant Burning?
need help
Just put a b20 in my eg hatch and it is throwing white smoke.
Keeps turning off on my on every stop light.
Could it be that my rings are bad ???
Former Moderator
Re: (oramac_eg)
Blown head gasket, bad rings/pistons, etc. - smoke can mean a lot of different things, and none of the possibilities are good ones.
Compression test?
Cooling system pressure test?
Have you done anything other than drive it so far?
Compression test?
no i haven't done a compresion test
or the cooling system
its my dd took it to the track a couple of time but thats it and for bolt on's just cold air intake and fuel rail and was running it open headers for about a month since my headers were to but for the piping but that is taking care off
Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">white smoke generally isnt rings, probably a head gasket issue. white smoke=coolant, black=oil</TD></TR></TABLE>
I was going to say the same thing.
Re: (skunk2chris)
the oil is problaly mixing with the coolant, problaly why your going through alot of oil.
sounds like the headgasket except for shutting off...
Re: (EJ1_Sleeper)
car is most likely shutting off cause of low compression or to much water in your cyl. I am going to say you need a head gasket also. Take off your rad cap and start the car...if water bubbles alot or gushes out your head gasket is bad that is the easy way to check if it does not bubble alot right away let the engine warm up so the t-stat opens up
Re: (EJ1_Sleeper)
pull out your dip stick and if the oil is a milk chocolate color than your oil and coolant are mixing. then you need a head gasket.
or if your exhaust smells sweet like radiator fluid you need a head gasket.
smoke is gone and the idle of the car is more steady stays at 1000 rpm still drops but has not been turning off not taking a risk gonna change the gasket
Re: White Smoke from B20 Swap? Rings? Coolant Burning?
This is an old thread make a new one.
But yes probably a blown gasket.unless you poured oil in your coolant
petrv
12
07-14-2003 06:33 AM
