motor swap questions
im swapin my motor from my GSR b18c1 in to a 97 civic ex and was wounderin if i could use the same hasport motor mounts from my integra into the civic. if not what ones should i get
Re: (xft)
You can just go ahead and get the hasport kit if you wanna spend the money. Otherwise when I did my B16 swap I had to get the rear tranny mount T bracket and then I had to get the upper timing side mount. Between the mounts that came with my B16, the original D16, and those two I pieced it all together.
318 Curves, 11 miles
Re: (civicjoe)
Yes, you need a rear tranny T bracket and a timing belt mount from a B-series EK. The GSR ones will not work. Meaning that you'll need one from a 99-00 Si or a DelSol VTEC. I don't believe that any others will work.
On the other mounts, D series mounts will work.
EM1 Resto
09-24-2009 01:28 PM
SyDuck
01-28-2005 06:59 PM
aw1234dude
06-28-2003 06:02 AM
