can anybody help me identify this wire????
I just got this car and the harness for the radio is messed up, so I re-wired it and got the radio working and wires got clean. I can't figure out where this one wire connected to, car don't have dash light and having a cel code which is bank1 sensor 2(replaced already).Can anybody help me with this. Thanks h-t.
2000 honda civic
2000 honda civic
Re: can anybody help me identify this wire???? (ryc555)
Well.... the Helms manual has a red/blk wire going into terminal four of the 8P heater control panel connector and labels it "Combination Light Switch" - so this makes sense. since it looks like it's supposed to control your dash lights. (which you say you don't have.)
If I'm right, the other end of that wire should be at fuse 30 in the underdash box. Is it blown?
Problem is that according to the wiring diagram, that same circuit went to ALL of the dash lights - list is:
Hazard Warning Switch Light
Gauge Lights
Audio Unit
Rear Window defogger switch light
Cruise indicator
A/T Gear position indicator
Dash Light Brightness controller.
Optional Connector (Dash Lights) (Whatever that means...)
A/T gear position console light
Heater control panel light.
My guess because of what you're saying is that it's either the heater panel light like I was talking about, or maybe the radio light dimmer input from the previous (or maybe stock before previous) install.
Gauge Lights
Audio Unit
Cruise indicator
Re: can anybody help me identify this wire???? (PerryRT)
thanks a lot man. I checked every fuse underdash box they are all good. Also, I noticed that my air **** for the a/c is not working when in MIN position, it only works when MAX.
black_coupe
10-16-2008 04:21 PM
