Need Help identifying some plugs
I have a 97 DX. I am installing an EX floor harness, and I am stuck, I took pictures of the fuse box to remember wehre everything plugs into, but there are two plugs that I can't figure out were to plug into. The first one is a yellow plug that comes from the floor, behind the cupholders, this one doesn't have anything to do with the floor harness, but I know it was connected before. The second one is a dark gray plug, I don't remember if it was connected before I disconnected the fuse box. Can anyone help me?
Re: (DAP97SI)
yellow does look like an SRS plug, try checking behind and above the fuse box. The grey one looks like the plug that the OBD2 code readers plug into.
Re: (mRek9R)
The yellow one is from a wire harness coming from the floor behind the cuplholders, it has four yellow plugs, one plugs into the rear of the steering wheel, one plugs into the actual fuse box, one on top of the fuse box, and the last one???????
Former Moderator
Re: (DAP97SI)
Just to repeat and reaffirm that largeer grey plug is where you plug in an OBD2 scan device for checking codes, emissions testing, etc.
coupedragracing
08-07-2011 06:36 PM
red_crx_89
08-22-2009 08:22 PM
Frost7177
04-03-2008 05:52 PM
litterbox
01-04-2005 05:56 PM
