gsr cluster
Re: gsr cluster (civicgsrb18)
it takes alot of re pinning the cluster plugs.most are color related from the dc plug to the eg harness. then im not sure if the gsr cluster will fit in eg dash. i did the full dash conversion. its alot of wires. and your rear dfrost switch will blow your "back-up fuse" every time you hit the button. you have to wire it to a unused fuse slot. long story short. dont do what i did. if you want to it buy a dash harness from someone and do it. if your take yours out after all that work and it not work righrt is a bitch. if you dont do it right everything goes wonky my speedo became my tac and my tac became my speedo. after alls said and done the dc dash and dc cluster looks way better than the stock eg
SoCaLNaTIvE
10-25-2006 11:53 AM
joenationwide
07-18-2004 08:37 PM
Spence
14
03-25-2004 04:50 PM
