Fuel filter
you have to hold it down with a monkey wrench 19 mm and then screw the banjo bolt off, on top and bottom. You cannot just remove the nut without holding the bottom nut, and remember to open the gas tank before you do this to release any air in the system
Be careful you do not want to strip you gas line, and make sure to clean the surrounding area that you used pb blaster in due to its oil content.
