obd1 B16 fault 13 Baro sensor
Hey, I just swapped in a JDM OBD1 B16A into my 95 Civic coupe. I have been getting the check engine light comming on as soon as it reaches operating temp. It had faults for the TPS, Map, and Baro sensors. The TPS was cracked so I replaced it and now I am only getting fault 13 for the Baro sensor. Is this different from the Map sensor? If so where is it located? Has anyone had this problem before? I searched but found nothing for it. I am using the JDM harness also. Any information would be appriciated.
Re: obd1 B16 fault 13 Baro sensor (95b16rr)
its the sensor on the inside of the ecu. the ecu uses it to compare pressure readings from the map sensor.
some have had success by replacing the map sensor, or in your case, make sure its wired up properly.
if that doesn't work, replace the computer
Boosted Chemist
06-15-2005 02:30 PM
