Dipstick Blowing Out
Old 03-13-2009, 07:35 PM
Jimhvis's Avatar
Default Dipstick Blowing Out
Anyone else have a problem with the dipstick blowing out? Only running 8lbs of boost, but everytime I get into it the dipstick blows out and shoots oil over the motor. Is this odd?? Suggestions?
Old 03-13-2009, 07:41 PM
iliv2xlr8's Avatar
Default Re: Dipstick Blowing Out
Replace your PCV valve. Just my thoughts, I have never had this problem, but it sounds like you have excessive crank case pressure.
Old 03-13-2009, 08:38 PM
New User
b6kinahan's Avatar
Also i bet the PCV...I Have not had this problem in any of my hondas...but it did happen to my 92 tbird and the problem was the pcv valve
Old 03-13-2009, 10:16 PM
2000siturboR's Avatar
yea you got excessive blow by. i had exact same problem then a month later motor went in my car. i would suggest to do a compession test. see what your numbers are. sounds like rings might be bad. dont want to burst your bubble but thats exactally how it started with me then the motor went.
Old 03-13-2009, 10:34 PM
Unseen Racer's Avatar
here is your answer. i have not heard of the dip stick blowing out. that must be some crazy **** though. lol. also check that you have the right dipstick. it should fit snuggly on the hole and should be tugged pretty nicely for it to come out. if it comes out easily then you will have to replace your dip stick.
Old 03-13-2009, 11:14 PM
team1320_k26eg's Avatar
crank case ventilation will help prevent that.
Old 03-13-2009, 11:38 PM
jtmartin96civic's Avatar
that sounds like a good place to start IMO. Compression and leakdown test. If those turn out acceptable, then I would look for the PCV valve next but THAT much pressure to push oil out of the dipstick tube sounds kinda severe man... Hope its just the PCV but heres how I always look at stuff like this, "dont be scared... be prepared for the worst.."
Old 03-14-2009, 05:31 AM
joelmatt89's Avatar
i agree with these guys do a compression and leakdown test asap, but before you do that try opening the oil fill cap with the engine running hopefully you have done this before to compare your observations with but if you haven't you should have some air blowing out but not much pressure, it should be effortless to cover the hole with your hand and keep the air from coming out
Old 03-14-2009, 07:30 AM
Jimhvis's Avatar
I will give that one a shot. I got in touch with my shop to see what's up. I'm settin up the appt for the leakdown test. He didn't sound very optimistic. I guess if that's the case then I'm lookin at a rebuild. Had planned to, but not for a lil ways down the road. I may also try replacing the pcv valve and the dipstick anyways.
Old 03-14-2009, 11:59 AM
joelmatt89's Avatar
can you feel air coming out the dipstick when you remove it with the engine running
Old 03-14-2009, 02:51 PM
single cam fan's Avatar
get a catch can
Old 03-14-2009, 09:26 PM
Originally Posted by single cam fan
get a catch can
x2 on the catch can as well every turbo honda should have them.
Old 03-14-2009, 09:29 PM
2000em1si's Avatar
the only time that my dip stick had blew out was when my motor blew
killudie123
11-06-2011 08:14 AM
THE BALANCE
07-01-2005 09:13 PM
TGUNNER
05-27-2004 04:27 AM
Quick Reply: Dipstick Blowing Out
