1994 Hatch slow progress BUILD
^day i got it^
Whats up the names Argenis I'm Dominican and this is my build.
This is a red 1994 Honda Civic Hatchback, it has:
:Engine:
-JDM B16a
-AEM intake
-DC headers
-GSR tranny
-p72 chipped computer
The only bad things with it are:
-Bad 2nd gear on the tranny
-Broken brackets on the headlights therefore cant align the front bumper until i get headlights
-I believe i have a bad head gasket you tell me...
^^^Is that a bad head gasket?
-Has a bad water pump.
-Needs paint job. Original paint used to be black and they painted it red for some reason.
FIRST PROJECT:clean interior and remove some sound deadning material.
Pics:
Putting interior back
Alignment problem
PLease comment all feedback would be excepted plan on updating as much as i can when i can so stay tuned and BUMP THIS PLEASE
Re: 1994 Hatch slow progress BUILD
Looks like it will be a fun project. The oil leak is not from the headgasket, most likely from the cam seal or the VTEC solenoid gasket. it just builds up there and below if for some reason, the headasket doesnt leak oil.
1 Post
do you have white smoke, rough idle, coolant loss? oil loss? oil in your coolant? coolant in your oil? overheating? that's the usual signs of head gasket.
I'm going to be doing mine this week I have white smoke, rough idle, loss of power, no overheating
i have a little bit of smoke at start up and it actually idles low and turns off some times so it is definitely not idling hard, at start up i do have loss of power and it bogs down when i accelerate it at start up, i do have coolant loss but that cause of the water pup, and i don't know if i have oil in my coolant or coolant in my oil. How would i check that? and no it is not overheating i actually think its under heating. which is also bad.
also my engine is not hitting VTEC could it be because there's is only one wire connected at the plug next to the solenoid...
I don't really know but mines does not line up because the lights sag since there are no brackets and the bumper where it meets the fender does not have the screws but i wouldn't know why yours do not line up sorry man.
You would know if you have oil in your coolant because your coolant would get creamy and thick. I was able to run my Mercedes for 6 months on a blown headgasket because of that. Definitely not a pretty sight. Its much better than if you had coolant in your oil, because then thats really bad for the motor.
That oil leak is NOT from the head gasket, but id replace it anyways, along with your cam seal, and VTEC solenoid gasket.
That gauge is a fuel pressure gauge.
I bet your swap was done in a back yard. It looks like a shitty swap to me.
Anyways, the ride is pretty clean so far. I like how the rims look on it too. Id ditch the EK fogs, the alignment is pretty much ugly. The painted spoon spoiler is pretty sweet too.
Get me a better picture of your engine bay. I want to help you out with your intake problem.
my lights sag also i think i have the same problem as yours. im also missing some screw from the bottom of the bumper lol thanks. how much did you get your EG for ?
Looks like you got your work cut out for you. I think the EK fogs look pretty good on the EG.
Also, there an appearance section that you can move your build there.
My Mercedes used to bog when cold too, I was never able to solve that problem.
also the swap came with the car when i bought it and the guy had papers to a shop that did it for him and did not charge him labor just 700 for the engine.
Also what should my fuel pressure be at?
Nice build man!
That doesnt look like a headgasket problem..like you said that seems like a bad water pump or failing water pump...that leak could be a number of things already stated as well as the Distributor O-ring. And that gauge looks like a Fuel pressure gauge of some sort.
you sure original paint was black? looks like its red unless they stripped every single part from it and painted the whole car red.
Looks like the orginal paint is red cuz of the red floors under the carpet. he just prob had a black bumer and painted it red.
is it just me or on the picture of the car on the right side the back wheel is missing a whole stud on it? lol that looks bad haha but looks like a fun build, lotta work
1. Engine bay:
2. Ground and right motor mount:
3. :::
4. Leak
5. This is the general area were the leak is coming from:
6. Solenoid and plug(notice only one wire)is that right???
7. intake|throttle body:
8. Different view:
9. Notice the car has been of for a day now without being turned on so why is the gauge reading???:
IF YOUR GOING TO TALK ABOUT A PICTURE PLEASE USE THE CORRESPONDING NUMBER THANKS
3. :::
4. Leak
8. Different view:
