camshaft and sprocket problem please help!
hi all. today i changed my camshaft to a crower stage 1. all was ok car started up ran fine for a while but wen i put the foot down i heard a knock and the car stopped and wouldent start. on closer inspection it turns out that the stud on the gear(sprocket) that slots into the grove in the camshaft broke off so the gear was spining but not the camshaft. so of corse i gota get a new sprocket but how can i match up timing again since its now f**ked up! any help would be great!
Re: camshaft and sprocket problem please help!
once u get the new cam gear on put it at TDC and the crank pulley at TDC of #1 piston. u should be fine then. did u lash your valves for the new cam?
ok cool thanks! i didnt lash the valves no. is it a must when upgrading to a stage 1? + if it is what shud i set them 2? this is the deepest iv gone into my engine before so bare with me im kinda behind! lol
O.G. triple O.G.
no the valves are fine and the timing belt! what happend was the sprocket on the camshaft pritty much rotated around the shaft instead of with it if you get me
u lash your valves anytime u change cams dude!! you should pull your head and check your valves they could be f**ked!
its just a thought
damn good point. the engine stopped strate away with no nasty sounds but i did try to start it again so couldof done more damage doing that?
yeah true. well first of all i will check them and see what ther like. if they are gone well least i got a 93 del sol with a b16a engine so i mite drop that in. shouldent be to hard since their all obd1 connections. my car is a 94 ex d16a by the way! shud of said that earlyier! lol
j0nptw
08-18-2005 02:03 PM
DOHClessEF-9
05-09-2005 10:17 PM
