HELP on 2000 civic
New User
HELP on 2000 civic
ok first off i have a 2000 civic 4Door Dx auto, Im having a hard time trying to fix these problems: its throwing codes are P1298"electric load Detector(ELD) circuit high voltage" & P0135 02 Sensor heater circuit malfunction, P1768 Problem in Torque Converter Clutch Solenoid Valve B Circuit. does anyone know how to fix these or do i have to replace my tranny ??? oh yeah i forgot to mention my cluster and lights are flickering and my speedo's going crazy too, and my lights dim and bright and my D4 light is blinking even in park and have to Drop down to 2 to accel, and when in D4 if i give it full throttle it doesn't get up and go. It just feels like its stuck in overdrive, and what is the normal operation temperature for the car? It's 189 right ??? and it jerks really hard when i change from park to D4 etc... i replaced the alternator already.
Re: HELP on 2000 civic
your p0135 is a bad oxygen sensor or wiring to it.... check your wiring then replace your sensor.... your ELD is a charging system problem... unfortunately i cant give u much help there... try and find a diag tree online from a shop manual. and your TCC solenoid is probobly sticking and or bad.... either way it probobly needs a TCC solenoid :-\. try that they arent very expensive but i dont have much experience on civic auto trannies so im not sure whether the valve body needs to be removed to replace that. hope i helped a little :-\
word of advise though is tackle one code at a time.
Not sure of the answers to your questions, but to clarify for you, the blinking D4 light is a trouble code. I'm pretty sure to check its code you do it just like checking the CEL. I'm not sure what the trouble codes mean though.
New User
yeah those are all the codes that i pull from my DTC devices that i use. haha yeah im trying to fix one problem at a time hahha. thanks for all the helps keep them coming.
DDDAAN Si
06-01-2011 05:52 PM
xTomei
23
08-25-2010 08:00 PM
