Yet another OBD2 Motor to OBD1
Alright, well... I'm gonna just post this to clarify. I know to make an OBD2 motor (ie D16y8) to an OBD1 you must change distributor, injectors, ecu, and do some wiring. Here are my questions
Distributor - Can I use my D15b8 distributor for this or am I in the market to find one from a D16z6, or any other type of motor for that matter.
Injectors - I believe I can use my stock injectors (d15b8) for these, correct?
ECU - What motor does this one come from... I take it that it needs to be V-tec which means that I would need one for a D16z6?
Wiring- about how difficult is the wiring and what are some general things that I will need to do???
Thanks for helping me clarify this, if there are other things the ones listed please let me know!
Scooter
Scooter
Re: Yet another OBD2 Motor to OBD1 (SlippylesKB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB »</TD></TR><TR><TD CLASS="quote">Alright, well... I'm gonna just post this to clarify. I know to make an OBD2 motor (ie D16y8) to an OBD1 you must change distributor, injectors, ecu, and do some wiring. Here are my questions
Scooter</TD></TR></TABLE>
im almost 100 percent sure that is not true.. i have an 98 obd2 b18c1 gsr motor in my 95 obd1 civic ex and all i had to do to make the motor run was install an obd1 p72 gsr ecu.. never had any problems at all..
Re: Yet another OBD2 Motor to OBD1 (Hybrid95CivicEX)
Ug... see I've got an amazing deal on a D16y8 just chillin in No. Virginia that I'd like to capitalize (I sound smart) on but I can't get just one definate answer. I just want someone saying "You need to do this and this and this"
well i can tell you forsure that an obd2 b18c1 motor to be installed into an obd1 car and all you need is the ecu.. i think it gets comlicated when you go from obd1 motor -> obd2 car.. i would take the offer on the d16 if its a good deal.. im debating on getting a complete swap d16z6 for 250 from a friend while i rebuild my motor from my accident, (not sure i want to do 2 motor swaps to same car in a 3 month period)
Cool, thanks a lot for your help. If you decide not to buy the d16z6... haha lemme know. I'll take it! Thanks again... Anyone else have anything to say about this?
Yeah i have had similar problems getting answer for this same question. Some people say just ecu, others say the injectors, ecu, and distributor.
Re: Yet another OBD2 Motor to OBD1 (MLogan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLogan »</TD></TR><TR><TD CLASS="quote">Yeah i have had similar problems getting answer for this same question. Some people say just ecu, others say the injectors, ecu, and distributor.</TD></TR></TABLE>
Ditto, I'm trying to put an end to this! I want the truth!
You don't need to change the distributor or injectors or ECU. As long as the wiring lines up, its fine. You can repin a OBD2 distributor and use it for a OBD1... same thing. Injectors are the same stuff as well... just different clips.
Re: Yet another OBD2 Motor to OBD1 (Bunger)
Thought you also needed an adapter for the distributor to plug into an OBD1 or was that to put an OBD1 into OBD2 I can't remember
6doorsentra
14
10-08-2006 11:36 PM
