Can I Hook up The Engine Oil to an "Automatic" Radiator(the oil coolant thing)
i just got a new radiator, and its a auto/manual style, so it has the ports for the automatic fluid lines. can i get one of those parts that go between the block and the oil filter, and have that cool my engine oil?? or will it like melt the radiator??
Re: Can I Hook up The Engine Oil to an "Automatic" Radiator(the oil coolant thing) (leprechan117)
those lines that go to the auto transmission is for coolant i believe. what you need is a oil cooler.
Re: Can I Hook up The Engine Oil to an "Automatic" Radiator(the oil coolant thing) (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos »</TD></TR><TR><TD CLASS="quote">those lines that go to the auto transmission is for coolant i believe. what you need is a oil cooler.</TD></TR></TABLE>
im pretty sure he knows this,im thinking he wants to know if he can use the tranny cooler part of the radiator as a oil cooler,i dont see why not,i dont think it will be as effeciant as a actual oil cooler but i thuink it would work.
im not sure about the honda radiator,but for most other ones its a totally seperate chamber made for tranny fluid,so oil would be the same.
Re: Can I Hook up The Engine Oil to an "Automatic" Radiator(the oil coolant thing) (civictypenos)
yeah, i know the differance, but i figure its there, why not use it for something?? it is a totally seperate chamber, at the bottom of the radiator.
the radiator is from autozone, its dual core, a little over an inch thick, one year warranty, and the best part..... its $99.99!! i couldnt believe that it was dual core, its great.
now that i know it might work, anyone know where to get that little block that goes between the block and filter??
i would like to know if/when you get this working. I would do the same to my car...i still have my automatic spec radiator but have converted to manual...
yea golden eagle makes one now i guess. its supposed to be used for ls-vtecs but im having a bitch of a time finding one. im pretty sure aem makes one to use so you can install an aftermarket oil pressure or temp guage
rcbusiness
Honda Civic (2001 - 2005)
07-13-2017 01:50 PM
skribblah
09-28-2003 04:45 PM
