HEadlight problem!!!
Old Apr 26, 2003 | 10:29 AM
SaltyHatch's Avatar
Default HEadlight problem!!!
Hey whats up everyone. Last night driving home I smelled like burning wires well it was a funky smell. Then when i parked my car i went to turn the headlights off and the stem was hard to turn. Now the headlights wont even go on now running lights either, so at night i have NO headlights and no instrument lights, its real fun. I just need to know what you think it may be a burned wire?...I checked all my fuses this morning and they were all fine both boxes, so I am totally stuck. My high beam work and so do my blinkers just seems the "stem" when i turn itsn't doing anything PLEASE HELP. I cant drive at night now it sucks. Thanks in advance
Old Apr 26, 2003 | 11:00 AM
SaltyHatch's Avatar
Default Re: HEadlight problem!!! (Honda Tech)
up up please help me
Old Apr 26, 2003 | 11:07 AM
JasonBlackEJ1's Avatar
i hate u too. dick.
Old Apr 26, 2003 | 11:20 AM
SaltyHatch's Avatar
Default Re: HEadlight problem!!! (JasonBlackEJ1)
thanks for the help i appreciate it
Old Apr 26, 2003 | 11:32 AM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonBlackEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">i hate u too. dick.</TD></TR></TABLE>
LOL.
Anyway, just sell that thing man. Nothing but trouble and it looks like it's launching all the time anyway...
Old Apr 26, 2003 | 11:58 AM
SaltyHatch's Avatar
Default Re: HEadlight problem!!! (JV)
i would like too but no one wants it and i need a car...so i would like to fix the problem but i dont know what to do!!!! ahhhhhh
Old Apr 26, 2003 | 12:25 PM
JICB16B's Avatar
if your running after market bulbs , that is prob. your problem. if thats the case, an HID conversion would have been cheaper and safer! sorry.
Old Apr 26, 2003 | 01:27 PM
SaltyHatch's Avatar
Default Re: HEadlight problem!!! (b18a1boosted)
i am running stock bulbs and i just checked again and no fuses blown out....it is driving me crazy i check ed the connections everything i am afraid it is a short somewhere and i dont want to rip apart the dash board!!!!
Old Apr 26, 2003 | 05:54 PM
SaltyHatch's Avatar
up up up
Old Apr 26, 2003 | 10:18 PM
SaltyHatch's Avatar
no one knows what it could be!!!
Old Apr 26, 2003 | 10:58 PM
2camsaam's Avatar
I am curious to learn if you have stock or aftermarket headlight housings or perhaps side marker lamps.
Check all of you aftermarket wiring for faults.
BTW, do your tail lights light up when the parking lights or head lights are on?
If they do not, then check the fuses under your steering wheel left of the clutch (if it is a 5spd).
You will probably find a 10amp fuse for the interior dash/tail lights/parking lights blown.
Old Apr 27, 2003 | 12:43 AM
SaltyHatch's Avatar
Default Re: (2camsaam)
stock lights only have lcear corners....i checked all the fuses and i will do so again tomorrow, i leanred something about removing the "stem" to see if the connection is made...how would i remove the stem!...tia
Old Apr 27, 2003 | 10:56 AM
SaltyHatch's Avatar
Default Re: (Honda Tech)
up up please i need to drive at night
b
Old Apr 27, 2003 | 04:17 PM
samdawgsol's Avatar
New User
get a wiring diagram and retrace it all. i think you have to buy a whole new light assemply switch stem thing.
Old Apr 27, 2003 | 06:34 PM
Outrun's Avatar
The contact of your switch burned out. It probably melted the plastic housing, which is why the rotary stalk is hard to turn. You will need to replace that whole part. Try a junkyard, as the switch assembly is about $150 from the dealer and $130 from an online Honda wholesaler.
Any switch from a 92-95 Civic and 94+ Integra will work. Other ones (EK, CRV, etc) may also work but I have no experience with those other control stalks.
It is easy to replace. However, you do have to use the airbag "short connectors" to disable the airbag. You don't want to mess around with the wires by the steering and accidentally pop the airbag.
Go to Borders or Barnes & Noble and look at a Civic Haynes or Chiltons. There is a basic diagram on how to replace the switch.
Basically, take off the top and bottom halves of the column cover. Unscrew the switch assembly and replace with a new assembly.
I took a ton of pics. I will try to find the CDR I put them on so I can post the pics.
Old Apr 27, 2003 | 07:10 PM
SaltyHatch's Avatar
Default Re: HEadlight problem!!! (Outrun)
that seems to be the problem now i am in search of a assembly....i need one ahhhhh!!!! thnaks though i appreciate it
1991 DA
Aug 13, 2006 09:16 PM
b20integrapower
Jun 26, 2006 09:31 PM
maruch
Jan 7, 2005 02:00 PM
speedycivicgurl
Aug 13, 2004 07:21 PM
