I need a pic of a rear motor mount from a 99-00 Si asap!!!
1 Post
Or, if you can tell me a way to distinguish the difference between a 99-00 si rear mount and a d series rear mount, that would help too.
Thanks
Thanks
Re: I need a pic of a rear motor mount from a 99-00 Si asap!!! (fowler)
I have a D series mount I can take pictures of.
Can you confirm that they are in fact different. Meaning you can't use the D series bracket on a b series swap in your EK.
Or are the holes in the same spots?
There were a few people before that said they reused ALL of their stock civic mounts when swapping in a B. I know the bracket by the timing belt is substantially different, but coundn't confirm the rear tranny bracket.
1 Post
Re: I need a pic of a rear motor mount from a 99-00 Si asap!!! (tonyXcom)
I've never checked them side by side. But that would be interesting to know that the D series mount worked.
But if you look at the photos, the hole is on different sides. I'm not sure what that means, but most likely, they won't work
ok, well I'll find out for sure. My buddy has a 99SI bracket that I can compare my D bracket too.
Ill post pics once I do.
the D series rear bracket/mount like the b series one showed above is not the same. the b & d's are different, i went threw that problem when swapping a usdm b16 into a 93 dx. the dx bracket is not as wide where it needs to be. and if i remember right the holes do not line up . and i think theres one more reason but cant think of it.
Re: I need a pic of a rear motor mount from a 99-00 Si asap!!! (EGsixer)
We are talking about 96-00 civics which are a different beast then an EG.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGsixer »</TD></TR><TR><TD CLASS="quote">the D series rear bracket/mount like the b series one showed above is not the same. the b & d's are different, i went threw that problem when swapping a usdm b16 into a 93 dx. the dx bracket is not as wide where it needs to be. and if i remember right the holes do not line up . and i think theres one more reason but cant think of it. </TD></TR></TABLE>
you can just use the integra mount for an EG. we're talking about 96-00 up in herr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">Can you confirm that they are in fact different. Meaning you can't use the D series bracket on a b series swap in your EK.
There were a few people before that said they reused ALL of their stock civic mounts when swapping in a B. I know the bracket by the timing belt is substantially different, but coundn't confirm the rear tranny bracket.</TD></TR></TABLE>
no you can not use the rear mount on a b-series swap. You have to use the Si mount. Been there done that....answer your questions?
Re: I need a pic of a rear motor mount from a 99-00 Si asap!!! (Civichatch2k)
yeah, that is what I have always thought, but there were at least 3 people in an older thread that said they reused all of their d mounts. I was like whatever.
Re: I need a pic of a rear motor mount from a 99-00 Si asap!!! (AWD 18T)
drive your *** over here then and bring your outie
oh ok. well if your wondering what rear mount to use in a 96-00 with a bseries you would use the 99/00 SI. not the stock dx.
I can has title
The easiest way for me to tell the difference between the mounts is that the 99-00 si rear mount has the triangular shape in the middle. Also if I am correct you can use 94-00 crv rear mounts for 96-00 b series swaps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGsixer »</TD></TR><TR><TD CLASS="quote">oh ok. well if your wondering what rear mount to use in a 96-00 with a bseries you would use the 99/00 SI. not the stock dx.</TD></TR></TABLE>
I know that because that is what I used on my C5.... But like I said, other people have said on here that they used the stock mount.
