can you take off the knock sensor and still run your motor ok?
Guest
Posts: n/a
ok my friend has a gsr motor and he said since hes runnign a chipped p28 and doesnt need the knock sensor i could have his. can i take his off and leave it off and not replace it on his motor? i mean will it hurt his motor if theres not a actual knock sensor on his motor??
Re: can you take off the knock sensor and still run your motor ok? (hatchboy93)
if he's running a p28 he wont need it, since the p28 doesnt look for that particular sensor. However if you remove it from a car that does use it, it will mess up your timing and performance will be like crap....
<----RSZero1 is unhappy his KS is still not wired up, but will have it done tomorrow....
EDIT: learned this the hard way....
Guest
Posts: n/a
Re: can you take off the knock sensor and still run your motor ok? (TODAeg6)
well he doesnt need it cuz he has a p28 chiped but i need it because i have a gsr ecu p72. but wil his motor be ok if i physically remove it from his block and not put something there in its place?
