1999 Civic - Speedometer works, odometer doesn't
Recent purchase.
So I had a tuneup (plugs,wires,gasket,o-ring,gas filter,oil change) but I'm not sure if the odometer stopped working because of this tune up or just later that same day.
I Googled a bit and most problems are with both the speedometer and odometer.
I'm not sure if it's the cluster or if there's a sensor, but I've tried just resetting the trip a dozen times to see if I could clear it up but no luck there.
I also suffer from bad idle vibrations especially when AC is on.
Re: 1999 Civic - Speedometer works, odometer doesn't
I'm a bit late on my followup but for anybody who has the same problem. I just kept hitting the trip reset holding it and now were good.
I also replaced my driver side motor mount that rubber overtime wears out, much smoother but I still need to replace the lower mount.
Akiyama
15
05-15-2011 11:01 AM
RaWrZie
06-03-2008 10:43 AM
