Can I use Fuel Grade Sealant to plug hole drilled in EVAP system shut valve?
Old 02-17-2014, 03:47 PM
TripleLude's Avatar
Default Can I use Fuel Grade Sealant to plug hole drilled in EVAP system shut valve?
Apparently, the previous owner drilled a hole in the trunk to mount an amp ground and drilled through the WHITE PLASTIC part that is considered the 'fuel vapor recovery valve' or something like that for the filler recovery. It causes a CEL for a P1432 or something like that.
Anyway, I thought about using silicon, but perhaps there is a better sealant out there I can squirt in that hole?
*edit*
2000 Civic EX Coup
Old 02-17-2014, 03:56 PM
Hysterically Calm
TomCat39's Avatar
Default Re: Fuel Grade Sealant (hole in vapor recovery)
http://www.henkelna.com/product-sear...=8797875666945
Loctite Gasket Sealant 2
Top Pick Loctite® Gasket Sealant 2 extended gasket life, slow drying, flexible cure. Loctite Gasket Sealant 2 is a reliable, paste-like gasket sealant, dressing, and coating. Sets more slowly to a pliable film best suited for non-rigid, vibrating assemblies. Use to 400°F. Resistant to gasoline and other solvents. Applications include valve cover and oil pan gaskets, threaded connections.
Technical Information
Applications
Gasketing > Gasket Sealant Dressings
Product information
IDH#
Item
Name
Size
Case Quantity
Material Safety Data Sheets
USA / English USA / Spanish Canada / English Canada / French
234889
30513
1.5 oz tube
12 / case
234889 (us/en)
234891
30514
3.0 oz tube
12 / case
234891 (us/en)
198819
30515
7.0 oz tube
12 / case
198819 (us/en)
235270
80964
5.0 gal pail
1 / case
235270 (us/en)
Old 02-17-2014, 03:57 PM
Former User's Avatar
Car information please.
Old 02-17-2014, 04:08 PM
TripleLude's Avatar
Oh sry:
2000 Civic EX Coup.
Old 02-17-2014, 04:46 PM
Which of these two ORVR valves?
Old 02-17-2014, 06:05 PM
TripleLude's Avatar
Hard to say by the diagram. It is large, white plastic, and I think it is round-ish. Located at center of trunk, right near the back seat.
*edit*
Oh wait, the diagram I was looking at before points to being the shut-off valve.
Old 02-17-2014, 06:14 PM
This one?
Old 02-17-2014, 06:17 PM
TripleLude's Avatar
I think so. Wow you have some good resolution images of the manual man.
Old 02-17-2014, 06:19 PM
Why not scout junk yards for 99-00 Civics and pull a shut valve out of one?
Old 02-17-2014, 06:51 PM
TripleLude's Avatar
Hoping to get a quick fix so it can pass emissions and I can run it through the engine break-in process. I have a 7/16" hole there now I can poke a tube through. Plus it has a full tank of Premium fuel for break-in.
I really need it back on the road fast and can pull the tank out later. Right now it is not registered due to emissions and I want it street-legal just to get through break-in. Time is an issue now for other reasons too.
Old 02-17-2014, 07:15 PM
How do you know that the drill bit did not damage the valve function as opposed to just made a hole in the valve body? In other words, even if you succeed in sealing the hole, how do you know the valve will actually work and not throw a code?
Old 02-18-2014, 04:07 AM
TripleLude's Avatar
The code is for basically the fuel tank cannot seal pressure.
Old 02-18-2014, 04:22 AM
Post the code. But what you say doesn't seem to rule out a broken/damaged valve.
Old 02-18-2014, 04:28 AM
TripleLude's Avatar
True, let me pull that code up on my laptop.
Old 02-18-2014, 04:30 AM
TripleLude's Avatar
Code: P1456 Power Train Manufacturer Defined
Old 02-18-2014, 04:39 AM
A loss of vacuum in the EVAP system or a bad shut valve can throw P1456. What I'm saying is that, even if you succeed in sealing the hole in the shut valve body, P1456 may still be thrown because the drill hole could have damaged the shut valve.
Old 02-18-2014, 07:37 AM
TripleLude's Avatar
Yea, I am aware that damage might have occurred. Here is a perfect example of why we should never trust car audio shops to install an amplifier.
So I guess I will first try the sealant method. If I can keep the code away for 30 miles, I can pass emissions testing and then run it through engine break-in to use up that near-full tank of gas.
After that, I will drop the tank and do it right. I hate messing with a full tank of gas. Just too dangerous. I'd rather drive it out first.
Old 02-18-2014, 07:53 AM
Default Re: Can I use Fuel Grade Sealant to plug hole drilled in EVAP system shut valve?
Good luck.
Old 02-18-2014, 02:07 PM
TripleLude's Avatar
Thanks for your help.
Old 02-19-2014, 05:53 AM
sowellman88011's Avatar
I wouldnt do any kind of silicoln theres alot of vacuum in that thing I believe it may just suck it into the hole. at that point if it did still work then it wont after that. probably better off going with something that gets hard like an epoxy. parts stores sell different strengths. the longer it takes to harden the stronger it is. even a quick 1 should do the job. but no matter what you use make sure it doesnt flow inside.
Old 02-20-2014, 03:59 AM
TripleLude's Avatar
I sealed it up with a fuel-grade sealant and drove it about 5-6 miles. No stored or pending codes, and all emissions systems appear to have completed their cycles. Today I will go to take the GA emissions test and hopefully it has enough miles on it for a pass.
cyclonedr
09-02-2019 01:09 PM
HiGhGuY
07-30-2014 10:13 AM
shortlid
03-10-2008 03:38 AM
darkfx
10-08-2005 09:51 AM
petrv
04-15-2004 10:51 AM
Quick Reply: Can I use Fuel Grade Sealant to plug hole drilled in EVAP system shut valve?
