92 Civic Brake Problem
I have a 92 civic hatch, "EG", and i dropped the car really low to the ground, and i noticed that my rotors and brake pads are kind of worn out, but whenever i crank the wheel either to the right or left, i lose all of my brake pedal. The pressure is gone and I have to straighten the wheel back before i pump the pedal back up.
When i'm driving normally the brake pedal is kind of soft, but not a lot at all, and they work just fine.
I was mainly thinking master cylinder, as well as the worn of the pads and rotors.
I've done research and a lot of lifted vehicles have this problem, and its because the suspension geometry a gets thrown off and it creates extra room in between the pad and the disk.
I was really hoping someone could tell me what the problem is. Thank you.
Re: Brake Problem
Just do a complete brake inspection, most places offer it for free or at very little cost. Probably your brake lines. Why so low in the first place? Perfect example of function over fashion.
What's your suspension/brake set-up?
Re: 92 Civic Brake Problem
In a condition that bound up the caliper their could be enough of a gap to cause the pedal issue you describe.
If this is the case you should be able to see the caliper hitting something with the wheels turned.
But my first guess would be a bad flex line.
