95 civic ex sedan - Power locks not working
Ok so i looked through a few pages in the thread and didn't really see anything that was helpful.....
Ok i acquired a 95 honda civic ex sedan for cheap.. i noticed that when i hit the door lock switch nothing happened on any door. I took off the door panel and the switch wasn't hooked up. I plugged it up and tried it and i hear what I'm assuming is the relay clicking. but still none of the doors are locking.. i started to think it was the actuator but what are the chances all went bad? Basically I'm stuck and don't know where to go from here. all locks work manually also. any ideas will be appreciated..
Re: 95 civic ex sedan - Power locks not working
I checked the fuse all seemed to be fine...But i have no multi meter to check with i just pulled them..reason i said relay was because i heard a clicking noise when i pressed the with up and down coming from inside the door.
You can buy an inexpensive multimeter for about $4 on sale at Harbor Freight Tools. You need this basic tool to troubleshoot any electrical problems.
i have his same problem, but even the manual locks wont work. like its hung up somewhere. i took the door panel off and couldnt see anything major. would failed auto locks have this effect?
Ok so I checked it today...I have don't have full battery voltage t the grn and wht and the grb and red
silent1jt
10-20-2009 06:08 PM
