massive amounts of white smoke
Well I finally got my car up and running and noticed the huge clouds of smoke coming from the exhaust. Figured it would be my headgasket, but I just put in ctr pistons and the mugen 2-piece headgasket so it shouldn't be. Where would be my starting point? Should I pull the head off and do a quick check to see if everything is alright? Get back at me
BTW b16, ctr pistons, head gasket, i/h/e, tb, fpr
Re: massive amounts of white smoke (dumped_ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchling »</TD></TR><TR><TD CLASS="quote">problay your head gasket did torque the head blots to spec</TD></TR></TABLE>
Followed the Helms to the T. Everything at proper torque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumped_ej1 »</TD></TR><TR><TD CLASS="quote">is it coming from the exhaust tip or the header?
check your oil levels and your pcv.</TD></TR></TABLE>
It was coming from the header and the exhaust tip. It stopped from the header, but now just from the tip
CEL....code 6 and 10.
Will do. I think I am going to pull a late nighter and replace the head anyways. Thanks.
* Oil full
* Oil full
Guest
Posts: n/a
Re: massive amounts of white smoke (Ag3nt_Orang3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ag3nt_Orang3 »</TD></TR><TR><TD CLASS="quote">CEL....code 6 and 10.
* Oil full</TD></TR></TABLE> well find out what the cels mean then and check your pcv
Found it! Leak where the head met the block. Was not quite sitting right. Switched back to other head and perfect now.
