Rear Fenders
Re: Rear Fenders (carbonk20)
are you talking about the pieces to fix rust ? if so i would like to know some stuff about it too because i need to do it i have lots of rust back there
well you can either fill it in with bondo? Or you can cut the rusted area out find a donor car that has no rust and cut that out weld new ones in grind then paint Bondo will crack.
Re: (carbonk20)
Your best bet will be to make patch panels out of sheet metal or get it off a donor car.....Make a template and mold/form the metal to desired shape.....Weld it in,grind it,get it as smooth as possible and if you do a decent job you shouldn't need to much bondo....Bondo will not crack if applied correctly and not exposed to moisture....I had to patch the rear quarters on an EF last year.....
g35silversurfer
12-04-2010 07:05 AM
ebpcivicsi1234
01-13-2004 01:18 PM
