Brake help
Brake help
Here's the deal, 92 civic hatch w/4 wheel disc, no abs. Everything has been changed which includes: master, booster, front and rear calipers and front brake hoses. THe problem is that after driving around for about 5 minutes the calipers will not release the rotors. If you jack the car up the wheels will not spin. If the car sits for about 5 minutes than it goes back to normal until you decided to drive again.
Anyone have suggestions??
check your brake caliper sliding pins if they move freely, they may need to be cleaned and lubed. if good, check your brake lines are not crimped. other than that you may have contaminated brake fluid ..ie engine oil in brake fluid that can cause seals to swell...
Ohannon7
02-20-2020 12:05 AM
RedDC5
02-22-2005 06:30 PM
