will 96-00 shocks fit a 92-95?
Re: will 96-00 shocks fit a 92-95? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Not the rear struts</TD></TR></TABLE>
how come?
how come?
Re: will 96-00 shocks fit a 92-95? (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">
how come?</TD></TR></TABLE>
The 92-95 Civic rear strut, on the fork part, is wider than the 96-00 Civic strut. Which means the 92-95 Civic rear LCA, is thicker than the 96-00 Civic LCA. If you shave down the bushing, I think it will fit.
The 92-95 Civic rear strut, on the fork part, is wider than the 96-00 Civic strut. Which means the 92-95 Civic rear LCA, is thicker than the 96-00 Civic LCA. If you shave down the bushing, I think it will fit.</TD></TR></TABLE>
you mean the EG ones are thinner and i would need to add spacers, rather then shaving anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">you mean the EG ones are thinner and i would need to add spacers, rather then shaving anything?</TD></TR></TABLE>
No, other way around. The LCA bushing on the 92-95 civics is thicker than that of the 96-00 civics. So you could add spacers to the shock on a 96-00 using 92-95 struts but not the other way around. I know this because I've done this.
Re: will 96-00 shocks fit a 92-95? (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
No, other way around. The LCA bushing on the 92-95 civics is thicker than that of the 96-00 civics. So you could add spacers to the shock on a 96-00 using 92-95 struts but not the other way around. I know this because I've done this.</TD></TR></TABLE>
cool thanks.
cool thanks.
Re: will 96-00 shocks fit a 92-95? (Gadget)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gadget »</TD></TR><TR><TD CLASS="quote">you just had to get the last word in didn't you..? </TD></TR></TABLE>
no, i did
no, i did
Re: will 96-00 shocks fit a 92-95? (verycleanhatch)
i have eg shocks that i want to put on my ek
from what i understand i need spacers...
what are we talking here, washers?
Re: will 96-00 shocks fit a 92-95? (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd »</TD></TR><TR><TD CLASS="quote">i have eg shocks that i want to put on my ek
what are we talking here, washers?</TD></TR></TABLE>
yup i just put my CRX d2 coilovers on my 97 hatch.
all you need to do is go to a hardware store. Take your LCA bolt with you(i had extras) and go to the washer section and find one that fits your bolt snugglin so it doesnt move around to much.
i ended up with 12 washers 3 washers on each side of the LCA so 6 on each side.
works great
works great
Re: will 96-00 shocks fit a 92-95? (The Lobster)
this is only the rear, correct?
incase they ever need to be replaced... will replacing my lca's with eg's work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd »</TD></TR><TR><TD CLASS="quote">this is only the rear, correct?
incase they ever need to be replaced... will replacing my lca's with eg's work?</TD></TR></TABLE>
no sir EK are 1 inch longer. or something like that
oh ya with the spacers the space is 10 mm...so 5 mm on each side...the washers i use equaled to 10 mm with 6 washers...so meassure them out since each washer is diff size.
1POINT8VTEC
01-24-2006 12:06 PM
zephyrantes
07-12-2005 07:20 PM
Shongku
08-05-2004 09:14 PM
JDMDC5888
04-04-2004 06:20 AM
