help dizzzy ecu question (solid cel)
i have a h22a4 in a 93 civic si. the tach was goin crazy so i went to change the cap and rotor. when i got the cap and rotor for my motor i noticed it was external coil.
my dizzy is internal coil. so i returned the stuff and went to put my dizzy back togther. now the car wont start. im not getting spark, and the ecu is throwing a solid code. (no blinks, just staying on check engine) did i fry the ecu or dizzy. need help fast this is my daily driver
also if it was the dizzy what dizzy is obd1 that will run an h22a4
I've been told that a solid CEL means there's something wrong with your ECU. Just make sure you're propertly jumping to check your CEL, or if you have any sort of toggle switch on it, double check the connections.
djsire
03-20-2006 08:04 PM
