mini-me help ASAP!!!!!!
guys i need help wit my mini me swap!!! its throwing code 43(fuel supply)
i have a 99 cx hatch with a D16y7 and i just put on my D16Z6 head and its just not gettin fuel for some reason.... wut should i do!
we tried y8 injectors at first and it ran for a bit and then threw the code 43, tried the y7 injectors, and same prob, then i hooked up the y7 intake mani and it worked ok, sputtering here and there.
Ek Forever y0!
Re: mini-me help ASAP!!!!!! (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">i really dont know
but maybe try replacing your fuel filter if its really old...</TD></TR></TABLE>
Fuel filter should be fine unless he uses skank gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">what ecu?</TD></TR></TABLE>
Make sure you have a vtec ecu bro.
Re: (joker4096)
Is the fuel pump any diff between the Y7 and Y8's?
If so, might wanna make sure it's capable of it...I don't see how it wouldn't be..but ya never know with these injected electronic POS's .
Anyways....more info.
Do you hear the fuel pump prime when you turn the key to the "on" position but DO NOT start it? What's your fuel pressure when cranking it?
the thing in the rear was for cruise control, the injector side has four holes, one above each injector that used sir injection and an extra vac thing, im going to jb welb all the holes and the vac and I'm pretty sure it will work. Wish me luck
Re: (joker4096)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joker4096 »</TD></TR><TR><TD CLASS="quote">the thing in the rear was for cruise control, the injector side has four holes, one above each injector that used sir injection and an extra vac thing, im going to jb welb all the holes and the vac and I'm pretty sure it will work. Wish me luck</TD></TR></TABLE>
i just put a vac cap on the nipple for the air injection, havn't had a problem with it yet. seems overkill to take off the mani and ruin it with jb weld.
i had a z6 head on my y7 the timing as always goofy, and ran funny. check to make shure that your plug wires arnt mixed up AND that your not 180* out of time, the car will still run when your 180 out.
should get a y8 head thats what i did before i did a full y8 swap.
I was told that this was a y8 head, but it had a z6 camgear on it. the valves look like y8 ones. it also came with a bare y8 intake mani so i do belive it is a y8.
I have a p28 i was using, with the jumper harness. When the new gasket comes in, im going to give you guys an update after i change the manifold to the y8 again with the air injection holes plugged.
Re: mini-me help ASAP!!!!!! (joker4096)
ok, so i try the mani with the holes plugged, everything looks perfect, idles great, but when i go to give it gas, it stalls. what coud e this problem?
hassan21
24
09-15-2007 10:25 AM
tr0n9h
10-30-2005 01:33 PM
xXx Justin xXx
10-19-2005 07:02 PM
