prop valve leaking.
prop valve leaking.
I changed da prop valve but still leaking. is der anyway to seal dis up cuz my brake fluid was cut in half in a month.
Re: prop valve leaking. (kit50si)
you can't fix brake fluid leaks like you would with motor oil. Make sure the fittings are tight, or else you'll need to go and buy new tubes from Honda.
Re: (instrument)
tighten with flare wrenches otherwise you will strip them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">
hope you have flare wrenches.</TD></TR></TABLE>
pcguy760
06-26-2007 08:57 AM
mingbling96
12-20-2004 10:19 PM
