B series coming out of EF going into EG....mount questions
like the title says, im takin a b series out of my ef and putting it in an eg...can i reuse any of the mounts?
also which stock eg mounts can i still use for the swap?
do i need to change the mounting brackets to gsr?
also in the EF im using b series axles from a 94+ integra with the inner cup swapped to work with a DA intermediate shaft...can i still use this combo?the axles were a little long in the EF and caused slight binding issues when cornering hard, but i think they should be just long enough to work in the eg...
thanks guys
thanks guys
Re: B series coming out of EF going into EG....mount questions (Suck my DX)
Shant, your pulling the hatch project? To much huh? bummer.
For the 4door you use all the 4door mounts but you use the B16 brackets, you might have to buy a 94+ integra rear bracket. As for the axles you should be fine.
Re: B series coming out of EF going into EG....mount questions (Luserkid)
well the eg is a coupe...i dont know if that makes a difference or not
so the 1g sir upper driverside bracket works?
so all the stock mounts are the same for a D and a B in an EG?
also if im trying to use the clutch from the cable tranny i only need to swap out the disc right? or does the whole assembly need to be changed?
No your going to have to get a rear bracket. Also you will need a drivers side and tranny side mount. That was the first swap I ever did(b16 in a eg). I then pulled the b16 and put it in a ef. so no you can't use any of the mounts. Sorry bro I have the rear bracket!
Re: B series coming out of EF going into EG....mount questions (oneslowstd)
tight...i just so happen to have an extra rear mounting bracket
correct me if im wrong but i believe i can reuse the stock D series tranny mount..
what about the upper driverside mount bracket? will the 1g sir one work or do i need an integra one? and then ican use integra driver and rear mounts right?
Well im not sure about using the stock mount on the tranny, But I do know you need a B series rear bracket, and you need a b series drivers side mount.
well i was informed that all the mounts are the same...so it looks like im just gonna run the d mounts with inserts...
the only questions i really got left are about the clutch and the upper driverside mounting bracket
senser310
01-27-2012 11:16 AM
