B20 swap into EK, will turn but not run!
the motor will fire for a few rotations but will not continually fire. i checked the ignition with a spark plug on the end of an ignition wire and it continually fired. it's getting fuel, i can hear the injectors recieve fuel when the car turns on. my timing is good. and i have compression. The check engine light is not on. it used to throw a TDC code but does not anymore. all it throws is 72 and 73 which are random misfires. here's my setup.
1996 ej6 4dr
OBD 1 b20b (the guy that had it before me had it in his eg, so he converted it)
ry-wire conversion harness from OBD 2a to OBD 1.
im pretty sure im running a p03 out of an OBD 1 single cam until i can get my p75
rewired the distribtor
Modified by doodooheadfart at 12:30 PM 11/22/2006
1996 ej6 4dr
BokudenNYC
06-10-2009 04:12 PM
bowen1481
01-17-2007 07:54 PM
happyabortion
15
07-18-2006 03:21 PM
