CEL 4 CPS
CEL 4 CPS
So I did searching on the crank position sensor and can't seem to find what I'm looking for. I was told that the sensor is in the dizzy, but don't know what it looks like. Does any one have a diagram of the lay out that I am supposed to be looking at? it would make it alot easier for me. Any kind of help is appreciated.
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">what are you working on ???? what you drive.</TD></TR></TABLE>
Forgot to mention that part. I drive a 92 civic hatch stock motor b15 non-vtec.
HT White Ops
Re: (ondahush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ondahush »</TD></TR><TR><TD CLASS="quote">
Forgot to mention that part. I drive a 92 civic hatch stock motor b15 non-vtec.</TD></TR></TABLE>
D15B7.
D15B7.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">D15B7.</TD></TR></TABLE>
or D15B8, depending on model.
OP: replace the dizzy.
Re: (schardbody)
OP: replace the dizzy.</TD></TR></TABLE>
Its b15b7. The sensor is in the dizzy correct? I was reading some where else that, it is also located near the timing belt in the area, so I was confused. I dont even know what it looks like so i googled it and didnt really find much was just looking for a diagram so I can get a better picture for what I'm looking at. So if i was to replace the dizzy, the code would no longer show? also I would like to bring up is that sometime I can't rev passed 3500 RPM, but when I turn the car off and back on the car drives normal. I was reading in other search topics that other poeple are having problems like me as well but didn't find to much. I'm also throwing water temp. code as well. I know the problem with that, there is no socket that can plug in thier so I'm going to get that re-wired, but would you think that would cause any other problems? from what I am having now?
HT White Ops
Re: (ondahush)
Its b15b7. The sensor is in the dizzy correct? I was reading some where else that, it is also located near the timing belt in the area, so I was confused. I dont even know what it looks like so i googled it and didnt really find much was just looking for a diagram so I can get a better picture for what I'm looking at. So if i was to replace the dizzy, the code would no longer show? also I would like to bring up is that sometime I can't rev passed 3500 RPM, but when I turn the car off and back on the car drives normal. I was reading in other search topics that other poeple are having problems like me as well but didn't find to much. I'm also throwing water temp. code as well. I know the problem with that, there is no socket that can plug in thier so I'm going to get that re-wired, but would you think that would cause any other problems? from what I am having now?</TD></TR></TABLE>
Your motor is not a B15b7. It's a D15B7.
Re: (Eran)
Your motor is not a B15b7. It's a D15B7.</TD></TR></TABLE>
Thanks for the correction. d15b7 iit is.
ShayneBishop
01-04-2006 06:19 PM
