car dying when push in clutch
i recently dida b20 swap in my ek
parts include skunk2 intake manifold, crane stage 2 cams, act fly wheel, exedy full face organic clutch kit, the timing is on, i ve checked 3 times. it has a b18 crank and rods new bearings and pistons stock b20z2.
no vacume leaks already fixed, no check engine lights.
at idle in neutral car is fine, if if push in the clutch the rps drop about 3-400 rpms
sometimes it dies. clutch hasnothing to do with vacume but i did install a vacume block. 3 people have looked at it andcant determine the prob. if i keep giving it gas it doesnt die also sometimes when driving and shifting between gears the car dies butwhen i let out of the clutch it starts back up.
this is a headache and i cant get any help here.
Re: car dying when push in clutch (96b20hatch)
when you change gears and hit the clutch, do you notice significant power loss as well??? or is it just on startup???
Re: car dying when push in clutch (quintb2000)
the power loss while shifting stopped when i adjusted the screw on top of the throttle body. i dont fell power loss at all the car actually dies.
ive tried adjusting te pedal by turning the rod in and out and no difference.
the rpms drop about 400-500 when clutch is pushed in. all my friends are stumped ive had to turn the idle up just to drive the car so doesnt die at every stop. really need help here the fly,clutch, pilot, and throw out bearing are new. no grinds and tranny is full. when i start the car it doesnt try to move and when the clutch is pressed in the car goes into gear perfectly. only prob can think of is maybe not aligned proberly.but only one way to put together. once again no grinds in tranny.
