Trying to figure out what these front spindles are from *pics*
I have no clue what these front hubs are from, is there any visual clues on the rotors/calipers that will tell me what Honda they are from? I think they are either from an EG or a DC. Can anyone visually tell?
Modified by drewboy at 11:48 AM 7/28/2007
Re: Trying to figure out what these front spindles are from *pics* (drewboy)
Measure the rotors. 10.25" diameter rotors are more likely to be Integra (9.5" Civic/10.25" Civic EX). Only way to tell the difference between Integra and Civic EX brakes are the calipers or check for the ABS wiring mounts. Check for screw holes on the knuckle, indicating they had ABS, which means it is from an Integra or Civic EX ABS (same brakes as Integra). If the rotors are 10.25" wide, but have no ABS wiring mounts on the knuckle, then they are from a Civic EX non-ABS. If you see two holes near the top of the knuckle where the balljoint connects to, then they are from a 90-93 Integra. Hope this helps.
mr abstract
12-27-2006 10:48 AM
Smashback
10
03-22-2005 12:33 PM
youngkow
11-14-2002 06:16 PM
