Swapping Gauge clusters?
Can a gauge cluster be from a 96-200 with a Tach be swapped into a 92-95 model civic with no problems?
Modified by EL Vap133 at 9:55 AM 4/18/2008
Re: Swapping Gauge clusters? (davefromPA)
https://honda-tech.com/zerothread?id=1053318
yes it can, but won't look right, but here is the wiring diagram...gl
Re: Swapping Gauge clusters? (ek4_b16a)
i know it can be done but he specifically said without any problems. looking wrong is a problem and extraneous wiring is a problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davefromPA »</TD></TR><TR><TD CLASS="quote">i know it can be done but he specifically said without any problems. looking wrong is a problem and extraneous wiring is a problem</TD></TR></TABLE>
That is all relative to "who" wants the cluster. If the OP doesn't think it looks wierd, then how is it a problem?
Anyway, to broadly answer your broad question, THE CLUSTER IS NOT PLUG AND PLAY AND WILL REQUIRE SOME EXTRA PINNING/REWIRING IN ORDER FOR IT TO FIT! If this isn't a problem for you, then I guess the install is problem free lol.
Could have searched for this answer too. Been covered countless times
