BAR' QUESTION!?
Re: BAR' QUESTION!? (jdmstockeg6)
As far as i know there is no USDM P30 ECU. Only thing i could think of doing is getting a USDM P30 and adding the exact same resistors for an auto ecu. How well that will work i dont know. But you really are in a pickle.
However i could see you using an Auto LS ecu. PM me if you want to know that route because i cant give that information over the net publicly.
if your going to bar your car as an auto then there is no hope because the del sol never came out here with an auto dohc vtec...if your just going to drive your car you might be able to use a single cam vtec auto ecu but then it will not have the fuel mapping and the redline is going to be too low.. hope that help..or you can convert your car to manual and find a us p30 and you can pass bar that way
if your trying to bar, as far as i know the state refs want to see the ecu for the engine and for the same year it came out from, ur probably better of going without bar if ur running the jdm block with auto, good luck. i wish our none ek si's came with them B's stock
jdmstockeg6
22
07-07-2008 07:23 PM
