Wierd Idle Problems! Please help
* B A N N E D *
Well Im still kinda new and a friend told me to post to see what are some possible solutions.
i have a D15b Sohc Vtec and i have no idea what the problem is.
like It idles at 1300 and jumps up and down to 1500 and back down like its breathing.
we changed the IACV and nothing same thing. but now the problems are somtimes it wil idle at 700rpm's and then the next time i turn on the car it idles at like 100 rpms like its about to turn off. i sole it by reving it to 6000rpms them it idles at the 1300-1500 rpm mark.
Please help! Ive searched but nothing matches what my problem is.(searched: High idle, Hoping idle, how to fixed high idle and much more with no solutions here or google.)
* B A N N E D *
Re: Wierd Idle Problems! Please help (97civic94gsxr)
No i havent... how would i go about doing that?
Thanks agian really appreciate any help.
^ x2.
is it just me or do people like to throw IACV's at anything with an idle problem?
The jumping rpms makes me think vac leak, but that wouldn't explain why it idles so low after replacing the IAC. what did you replace it with? new or used parts?
Re: Wierd Idle Problems! Please help (ReactioN)
Does the CEL work and is it ON? Are any CEL codes retrieved from the ECU:
https://honda-tech.com/zerothread/1901557
* B A N N E D *
Re: (Kuchtaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kuchtaboy »</TD></TR><TR><TD CLASS="quote">^ x2.
The jumping rpms makes me think vac leak, but that wouldn't explain why it idles so low after replacing the IAC. what did you replace it with? new or used parts?</TD></TR></TABLE>
i did replace with a used one.
So how would i check for a vac leak?
and whats a vac leak.(will search after done posting)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">Does the CEL work and is it ON? Are any CEL codes retrieved from the ECU:
https://honda-tech.com/zerothread/1901557</TD></TR></TABLE>
The CEL is on and i havent Im gunna try that when i have time.
Modified by ReactioN at 7:24 AM 3/6/2008
b20eg9daddy
10-25-2008 12:37 PM
