rewiring gsr altenator plug in a 2000 si
I have a 2000 si and I am swapping in a 98 gsr motor. I am using my harness but the plug is different on the gsr altenator. does anybody know how to match the color on a si harness to a gsr plug cuz the wire colors are different.
Re: (99hondacura)
I will double check but I don't think they are. can I just put the plugs side by side and wire them up the way look on the si plug?
Re: (jay-d-em)
the gsr plug wire colors are :white/yellow, solid blue, black / yellow, white/ blue
the plug wire colors on the 2000 si
harness are: black/yellow, white/ green,
white/ blue, white/ red.
Re: (jay-d-em)
well I wired the plug. I dunno if I did it right I just match the wires from the si plug by putting them in the same location in the gsr plug. hope it works.
Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-d-em »</TD></TR><TR><TD CLASS="quote">well I wired the plug. I dunno if I did it right I just match the wires from the si plug by putting them in the same location in the gsr plug. hope it works.</TD></TR></TABLE>
Actually, that is right. You have 2 plugs, 8 pin and 2 pin, and then 1 plug with 10 pins but only 9 leads, no? Match them color for color and you will have an extra ground that is no longer necessary. You should be set.
Re: Re: (Blk00EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 »</TD></TR><TR><TD CLASS="quote">
Actually, that is right. You have 2 plugs, 8 pin and 2 pin, and then 1 plug with 10 pins but only 9 leads, no? Match them color for color and you will have an extra ground that is no longer necessary. You should be set.</TD></TR></TABLE>
Its the altenator plug I am converting which ony has 4 wires.
