Grinding gears.....HELP
Okay when i bought my car this problem did not exist. then i started to notice that in a high rpm my car would grind going into second and it also pop out of gear for no reason. so time went on and now third gear is starting to grind going into gear also dose anyone know whats wrong wiht my car?
TIA
TIA
Re: Grinding gears.....HELP (slo_hatch)
thats what i figured do you think letting it run like that would mess anythign up? and sould i get them fixed soon
Re: Grinding gears.....HELP (Dkober101)
i dont think there is really that much to worry about. i just hate the damn noise. but eventually it will mess up your tranny but i dont think syncro's are that expensive to fix. its just the fact that you have to take the tranny out and everything. i need to do it to the si tranny in my hatch.
Could be different things...could be worn/broken shifter forks, could be an un-seated bearing, could be low/no fluid, could be the PP/clutch.
Good luck!
Good luck!
It's one of two things or both.
Broken shift fork or syncro's. either way the tranny needs to get rebuilt. If you can do the work yourself, which I doubt because your asking. It will be fairly cheap. If you have it done, plan on $1000.00.
If you can remove and install it you can save some.
I did that once and had the pull it back out because the shop messed up and the tranny wouldn't go into reverse.
Figure what you can do or want to do. Do you have a good set of tools? Do you want to replace the clutch while the trannys out ? How long do you plan to keep the car? what do you plan to do with the car, turbo?
I'll bet you thought this was going to be easy...
Re: (1992Si)
I did that once and had the pull it back out because the shop messed up and the tranny wouldn't go into reverse.[I]
Man i would be one ticked off dude if I pulled it out and put it in, to pull it back out. I woulda rolled it to the shop and said you messed it up here you go fools.
RTW DC2R
09-05-2003 07:36 AM
sshaikh01
17
03-06-2003 06:27 PM
