How to stop the rattling interior noise ?
Old 11-04-2004, 02:23 AM
VTECMaster's Avatar
Default How to stop the rattling interior noise ?
yeah i did a search...
simple question: how can i make the rattling sound stop while driving with a stiff ride?
i already stripped the interior once, and used some isolating soft rubber material (i don't know its name) but it brought nothing...
what do u guys use? or did u all throw your side panels out?
thx for your answers!
greetz
Old 11-04-2004, 04:32 AM
VTECMaster's Avatar
Default Re: How to stop the rattling interior noise ? (VTECMaster)
bump
Old 11-04-2004, 04:36 AM
monicle's Avatar
well it could be a few different things causing it. It cood be a piece of the wireharness vibrating against the side of the panel. It could be one of the light grey pop-in clips thats rattling. A loose bolt with a washer rattling. Or a metal clamp rattling on the panel or the body. First you need to determine where the rattle is coming from and then check for one of these issues. Its usually going to be a harness or one of those grey clips though.
Old 11-04-2004, 04:59 AM
VTECMaster's Avatar
Default Re: How to stop the rattling interior noise ? (monicle)
thx so far! never thougt about the harness...
so, when i discovered where the noise is comin from, what du u suggest to isolate?
Old 11-04-2004, 05:15 AM
monicle's Avatar
well lets say you hear it coming from the rear drivers side panel. youre going to need to take the panel out first off. then check all those grey clips by lightly pulling or wiggling each one. If they feel loose then what you can do is slide the clip off the panel, then get some masking tape and slap a little piece of tape on the panel where the clip goes and then cut out the area where the clip slides in, then slide the clip back in. This will take up a tiny bit of space between the panel and the lip on the clip. should take care of it.
If it happens to be the harness then you can just go get some foam tape and wrap the harness wires with it. problem solved.
Old 11-04-2004, 05:58 AM
VTECMaster's Avatar
thx!
TKO Performance
03-05-2016 07:49 PM
Austin_tacious
10
05-31-2012 05:57 PM
heyimrchills
11-17-2009 11:54 AM
EK k kay
Audio / Security / Video
11
09-06-2005 07:09 PM
Quick Reply: How to stop the rattling interior noise ?
