Sparco Seat Question
Ok im trading some wheels for a sparco Pro2000 seat... but the seat is in a 96-98 style civic coupe... i have a 92-95 coupe.... well anyways i was wondering if i could use my stock sliders on the base mount for the sparco... sparcos website says that their universal base mount can be used when stock sliders are availiable or something.. i guess my question is will this work without me buying anything?
im pretty sure the seat has the universal base mount on it
Re: Sparco Seat Question (JDM EJ1 95)
When I had my Corbeau, it had one peice base/bracket/slider assembly that bolted to the bottom of the seat. I'm not positive how the Sparco is, but if it's a bottom mount seat like the Corbeau, there's no way you can use the stock sliders without a LOT of custom welding.
Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 »</TD></TR><TR><TD CLASS="quote">i looked around and sparco doesnts eem to sell vehicle specific parts... </TD></TR></TABLE>
Strange. I'd like to see a picture of the rail/slider assembly for it.
For use when original sliders can be removed from the seat. Also allows height adjustment.
(im not sure if this is what it has on it but its just an option..)
If it does have a vehicle specific mount on it would the 96-98 civic mount wrok with my 95 civic?
Re: (JDM EJ1 95)
You buy a seat bracket for your car, then universal sliding rails if you want them, and usually the adjustable side mounts, as well.
Seat sat pretty high in my car. Blah.
Re: (JDM EJ1 95)
I've had EK seats in an EG with a little bit of work but then in a different year they did'nt even come close to fitting and it was the same model eg even
Re: (sans)
Ok let me clear this up. I ahve a Sparco Fighter. Similar to your Pro2000
Pro2000
Fighter
Now my fighter seat has bottom mounts. Meaning the seat bolts from the bottom. From what i could find out it seems the Pro2000 has both bottom and side mounting positions. THis is good. You DO NOT need side mounts. It will only make your seat taller not lower.
Ok there are two things you need to buy. NO, stock EG brackets and sliders will NOT work. You need to get a Sparco Mount Base for your year car. Do not get the ones with the tubes they suck. There is a newer one made of laser cut metal. Really flat really low. Then you need the Sparco Sliders. These run about 150 all together. The base will bolt down to your car (jsut like your old brackets) then the sliders bolt onto that. and the seat is bolted on to the sliders. OF course this is not how you assemble it. You need to bolt everything onto the seat first.
Here is a pic of the bracket and slider on my knockoff recaro
Pro2000
Fighter
1 Post
Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 »</TD></TR><TR><TD CLASS="quote">so theres no possible way to make it work without buying a new mounting base?</TD></TR></TABLE>
Correct.
EG and EK used different base bracket designs.
Correct.
Re: (JDM EJ1 95)
3/4 bolts will bolt down (i think). if the eg rails are anything like the del sol, only 3/4 bolts bolted up for me, so i swapped the rails. i beileve at least he'd be able to drive home with 3/4 bolts, dunno bout your sparco.
ok so what if he swapped his stock rails onto my seat and i took my rails off and threw them on the sparco would that work at least for him?
Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 »</TD></TR><TR><TD CLASS="quote">ok so what if he swapped his stock rails onto my seat and i took my rails off and threw them on the sparco would that work at least for him?</TD></TR></TABLE>
Ok uh what this guy can do is (if he still has his stock seat) swap the STOCK EK rails onto the seat in your EG. The Sparco will not fit onto any honda seat.
ok cool ill just swap him my seat for now.. 3 of 4 bolts will bolt up for him so he can at least drive it and be somewhat stable.. my car isnt driving right now i crashed it so i have plenty of tiem to pick up the parts i need.. thanks everyone
rice_classic
12
05-05-2004 11:33 PM
