Question about b20 short & long blocks ...
#1 Super Guy
Re: Question about b20 short & long blocks ... (jdizzle00)
A short block is the lower half of the motor (block, rods, pistons, crank), a long block is the whole motor (head, block, valve cover, oil pan, valve train, distributor, blah blah)
A vtec head won't just bolt onto a b20/b18b block. You must plug the vtec oil feed on the vtec head, and machine the dowl-pins holes on the head to match the dowl-pins on the block. Then you must run an external vtec oil line to the head...
Re: Question about b20 short & long blocks ... (94eg!)
ok well i gotta 98 b20b short block...n a 98 gsr head...whats everything i need to do to get dat bad boy runnin?
dowel pins for the block, GE sandwhich plate with 2 fittings for your block or just get it tapped, take head and have it tapped for vtec oil line, oil line from block to head, need to use a GSR engine harness
Re: Question about b20 short & long blocks ... (FUKuPAYme)
haha...alright thanks on the info bro...if nething else i need to know? it would be greatly appreciated!
You can buy "stepped" dowel pins on e-bay [same ones inline four includes with their kit] for $20 shipped and buy the fittings and hoses from summit, and plug and tap the block yourself to save $. I did my B20 and have had no probs.
blinx9900
12-30-2008 10:01 AM
Jap_Spec_Imports
09-24-2008 09:01 PM
