h22 hatchback
h22 hatchback
i'm lookin at buying a 93 vx with a h22 swap. its cpu is reprogrammed and some other small things. the drivetrain is immaculate, but the body is unpainted with nothing done to it. the interior is a little rough also... i'm gonna have tp put 2k into it. Hes asking $4250... good deal or not?
Re: h22 hatchback (90g2ls)
That sounds like a good price. Here's what you could have http://www.tunedbylorange.com check this shop car out H22 hatch.
H-T Order of Merit
Re: h22 hatchback (ek9hatch0WN3R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9hatch0WN3R »</TD></TR><TR><TD CLASS="quote">whats this extra 2grand you need to spend on it for?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honhatch3 »</TD></TR><TR><TD CLASS="quote">but the body is unpainted with nothing done to it. the interior is a little rough also</TD></TR></TABLE>
I'm assuming it's to paint the extreior and do what needs to be done to the interior.
Re: h22 hatchback (VvPeachyvV)
everyone i talk to (including a shop that specializes in hondas/swaps) says that h22, if yuo miss an oil chang eor something is like the kiss of death. other than that i would like to go with it. that true?
Re: h22 hatchback (Import_Dumbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Dumbass »</TD></TR><TR><TD CLASS="quote">everyone i talk to (including a shop that specializes in hondas/swaps) says that h22, if yuo miss an oil chang eor something is like the kiss of death. other than that i would like to go with it. that true?</TD></TR></TABLE>
It may be true, only because H22's tend to burn oil during Vtec...you can literally see the smoke. If you don't drive hard or anything, you should be alright. The price is right on the hatch though...I'd buy it for that price if I had the $$
Re: h22 hatchback (honhatch3)
The only problem you should have with this motor in that car is the front being to heavy and the back of the car will get loose in a turn if its raining so you would need to put bigger springs and struts.
Re: h22 hatchback (00supercivic)
how would you know the "drivetrain is immaculate"......did you crack it open and investigate..........my old type r was fast as **** but still had 3 bent valves
Chokolatecake
37
02-07-2005 08:26 PM
