Need Fuse block pin outs for CX civic (92-95)
I did a search found lots of completely incorrect info. Im fixing my mess of wiring from my integra dash conversion. I used the integra harness with civic fuse block plugs. All teh signals work, headlights, higebeams work
On the cluster side of things, I know what everything should be
<U>13 pin plug:</U>
1- Immobilizer
2- Immobilizer
3- Not Used
4- Power
5- Maintenance Light
6- Cruise control
7- Ground
8- Coolant Temp
9- Battery Light/Charge Indicator
10- Not used
11- Oil Pressure
12- CEL
13- Tach Signal
<U>16 PIN Plug</U>
1- Fuel Gauge
2- Door Indicator
3- Not used
4- Low Fuel Indicator
5- Not Used (?)
6- Speedometer
7 -Trunk Light
8- Seat Belt Light
9- Power
10- Power
11- Power
12 - Not used
13- Left Turn signal
14- Right turn signal
15- High Beam
16 - E-Brake
So somewhere along the way i screwed up most of the actual gauges. So if anyone has the layouts for the fuse block side, it would be greatly appreciated.
<U>13 pin plug:</U>
1- Immobilizer
2- Immobilizer
3- Not Used
4- Power
6- Cruise control
7- Ground
8- Coolant Temp
10- Not used
11- Oil Pressure
12- CEL
13- Tach Signal
<U>16 PIN Plug</U>
1- Fuel Gauge
2- Door Indicator
3- Not used
5- Not Used (?)
6- Speedometer
7 -Trunk Light
8- Seat Belt Light
9- Power
10- Power
11- Power
12 - Not used
15- High Beam
16 - E-Brake
dbailey
01-05-2006 06:04 PM
mz3bo
08-27-2003 07:42 PM
