will an ek coupe exhaust manifold, mid/b-pipe and cat work on an ek hatch?
My dx hatch has the cat/exhaust mani combo in one piece and I was wondering if I could get the exhaust manifold from a coupe along with the cat and mid-pipe and put it on?
Moderator
Re: will an ek coupe exhaust manifold, mid/b-pipe and cat work on an ek hatch? (chowmien)
it should fit....
get
header
cat
mid/b pipe....
rear section is longer on the coupe....but i believe everything else is the same
get
header
cat
mid/b pipe....
Re: (yoshi_1r)
I found out the hard way : Make sure they are the same motor. A Y8 exhaust manifold will physically fit on a Y7 (CX/DX) motor. BUT the oxygen sensor on a Y7 is on the lower portion -vs- (Y8) right on front of the maifold. I had the option to look for a Y7 Manifold OR lenghten the wires. Its up to you, hope this helps
Re: (EK-Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-Chris »</TD></TR><TR><TD CLASS="quote">I found out the hard way : Make sure they are the same motor. A Y8 exhaust manifold will physically fit on a Y7 (CX/DX) motor. BUT the oxygen sensor on a Y7 is on the lower portion -vs- (Y8) right on front of the maifold. I had the option to look for a Y7 Manifold OR lenghten the wires. Its up to you, hope this helps </TD></TR></TABLE>
Don't you mean the Y7 exhaust manifold has the o2 sensor right on the front VS the Y8 has it underneath? I could prove this because I own a d16y7 and my exhaust manny has an o2 sensor coming from the front sticking right next to the A/C fan. There is also another o2 sensor running right after the cat.
Re: (EK-Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-Chris »</TD></TR><TR><TD CLASS="quote">Yeah, sorry.. </TD></TR></TABLE>
No problemo We're all here to benefit from eachother's information.
94 IntegraLS
06-21-2011 06:17 AM
Team_Insane
05-12-2011 08:25 PM
jdmjunkieXL
05-01-2006 10:53 PM
