Brake Swap?
Brake Swap?
I am doing an itr brake swap for my eg for front brakes and gsr rears. I was wondering if i would need the proportiong valve?
I have already the gsr rear brakes completly assembled and the itr rotor and calipers gsr front spindles, brake booster, master cylinder
i still have to get the ebrake cables and lines
also is there anything else i would need?
thanx
thanx
Mr. Badwrench
Re: Brake Swap? (blucivicsi99)
some say you need a prop valve and master cylinder and some say you dont. me i say if you are converting to rear disc, you need a rear disc prop valve. the brake bias is not correct if you dont. i have my stock si master cylinder on an itr 5 lug swap stops fine. i would do a prop valve as well. and just curious, the itr fronts are they 5 lug? and you have a 4 lug rear? just wondering why?
Chad what would u say about the prop valve. i know u havent said anything to me about it when we talked i figured if i did u had just forgot and was going to ask u when i called tomorrow but i decided to post up. but i looked up a how to on here and the guy that did it said something about it so i was just wondering
by the way like the new race car reminds me of my old car
Re: Brake Swap? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">you aren't doing an ITR brake swap!!! itr brake swap is 5 lug....</TD></TR></TABLE>
not if its a 96 or 97. i think ones of those years was 4 lug
Moderator
Re: Brake Swap? (h23eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23eg »</TD></TR><TR><TD CLASS="quote">
not if its a 96 or 97. i think ones of those years was 4 lug</TD></TR></TABLE>
4x114.3.....not 4x100
haha
haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">K SERIES EG.....that should help you forget your old car!!!</TD></TR></TABLE>
That is true
That is true
Re: Brake Swap? (boostedcivicsir)
so it's not for anything but setting it apart from the rest? That's what I thought, it's just an extra lug, not like it add's 20 hp.
WHITE DEATH
07-05-2006 10:12 PM
