how to pu a 99 si strut bar onto an eg coupe
Moderator
Re: how to pu a 99 si strut bar onto an eg coupe (chad)
i replied but since you found the need to bump after SIX minutes i pulled the information down.....
Re: how to pu a 99 si strut bar onto an eg coupe (jspresso)
it will bolt right in.
Your EG came predrill, just peel the sticker that over the hole up and you are ready to bolt in.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i replied but since you found the need to bump after SIX minutes i pulled the information down.....</TD></TR></TABLE>
Thats helping the guy how? Maybe he already has the bar and is waiting for help to put it on right away......
Mr. Badwrench
there should be 2 plugs, on each side of your car at the strut tower. place the bar where it goes and you will see them. take out the plugs, nut and bolt voila. done. did it that way in the b-sir.
Re: (boostedcivicsir)
maybe its like that on the exs and si but i have a dx with probably everthing ex on it but no holes but thanks gies looks like ill just get drilling
Re: (jspresso)
just check it looks like there might be some covered holes or like indents of some sort if someone has a closeup pic of one post it please it will be greatly appreciated
* B A N N E D *
1 Post
Re: (jspresso)
https://honda-tech.com/zerothread?id=972851
this may help, for a EK, but theory and work is identical.
Re: (jspresso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspresso »</TD></TR><TR><TD CLASS="quote">just check it looks like there might be some covered holes or like indents of some sort if someone has a closeup pic of one post it please it will be greatly appreciated</TD></TR></TABLE>
on the shock tower,...there should be two hole predrill and cover up with match paint plugs. Just peel those off and you can bolt the strut bar in. If it dont came predrill then you will have to drill it yourself. But why drilling holes for a stock struct bar, when you can purchase some strut bar that can bolt onto the shock bolts that require NO DRILLING.
grandmasterflex
04-20-2004 07:03 AM
Hybrid96EK
10
10-23-2003 05:23 PM
