99 EX Drum brake question
I know there’s a good chance that this question has been asked before but every time I try to search I get~
"The search server is temporarily unavailable. Please try again later."
Its been like that all day; but anyways,
I was thinking about converting my rear drums to disk brakes. I was going to go to a local junk yard and find some off of an Acura. If someone could instruct me on what all I need to take besides the rotors and calipers off the Acura/and some pointers on installing them on my car, that would be great.
(Or send me a link to a past post if the search is working for you)
Thx a lot.
Thx a lot.
Re: (VTAKKK!!)
In this forum fourth sticky from the top-
***Post Links to Helpful FAQs So We Can Get an Archive Going*** ( 1 ... 7 8 9 ) Has a lot of info for you and swaping your drums to disc. I highly recommend checking it out. Good stuff.
Re: (VTAKKK!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTAKKK!! »</TD></TR><TR><TD CLASS="quote">im not sure about the trailing arms but, e- brake cables, brake lines, proportioning valve </TD></TR></TABLE>
You don't need the trailing arms, but most people just do it becuase its generally easier to just swap the whole thing. But I know from experience that the trailing arms are interchangeable, as the Teg ones that I got were bent, so I just used the spindles etc from the Teg and the trailing arm from my car.
-Shane
-Shane
Re: 99 EX Drum brake question (EJ8 Jim)
grab a proportioning valve of a 99-00 si, youll need this or the brakes wont work right. Its easiest to just grab the whole trailing arm assemble and swap it all, gsr
e-brake cables work but youll have to makeshift a way to bolt em down. your best bet if you just want rear disc is try to find it off an SI. it'll make it a lil easier, its def worth the swap though
SearchBeforeUPost!
01-26-2003 09:20 AM
